Alt 02-07-2008, 12:30
Benutzerbild von Commnews-RSS
Commnews-RSS Commnews-RSS ist offline
RSS Sklave
Commnews-RSS hat noch keine Bewertung oder ist auf 0
Post Unitprofil: Apollo Fighter
  • Aufgabe: Luftüberlegenheitsjet
  • Hersteller: Angstrom Defense
  • Herkunftsland: Schweden
  • Gebaut in: Alliierte Airbase
Features:
  • 20 mm PV-7 "Sol" Bordkanone
  • Senkrechtstarter für schnelle Aktionen
  • Dreifachschubvektoren für optimale Stabilität
  • Upgrade erhöht Aufklärungsreichweite und Waffenkapazität
  • Gebürstete Titanoberfläche widersteht Ruß und Rost
In spite of the combined treasuries of Allied nations, ongoing struggles against the Soviet war machine have proven undeniably costly. As a result, the Allies have increasingly sought to fill their military with highly specialized and efficient machines that perform exceedingly well in a given role yet work best as part of a combined-arms strategy. One of the finest results of this philosophy is the F-11X Apollo Fighter, born from Stockholm-based Angstrom Defense and now seeing active duty throughout at least a dozen nations. This is one of the world's best, fastest, most dangerous air superiority fighters.
Like other Allied aircraft, the Apollo features a VTOL (vertical take-off and landing) engine configuration, which provides maximum stability and maneuverability. This also lets the Apollo operate effectively in urban environments as well as out in the open. The sight of this delta-wing jet hovering in place is almost uncanny at first, yet its triple thrust vectors somehow hold it aloft with near-perfect stability--all the better to let the Apollo bring its 20 mm "Sol" autocannon to bear on any enemy bogies. The Sol is a single-barrel weapon yet can spit out 500 rounds of armor-piercing ammunition per minute easily. Moreover, it is extremely accurate for such a weapon, partly due to the Apollo's own targeting systems and maneuverability. Once an Apollo has marked an enemy target, there is little the enemy can do to escape the Apollo's withering fire, especially because the Apollo can outpace virtually any other aircraft. The Apollo Fighter is very direct in its design. For better or worse, it is armed with a more-conventional weapons system than some of the latest, more-experimental Allied vehicles (not the least of which are Angstrom Defense's own Cryocopter and Athena Cannon). However, a little-known fact is that the Apollo underwent several bids and design iterations before the Allies finally accepted the model currently in use. Predecessors of the F-11X lacked the VTOL engine configuration, which made them far more nimble in the skies but also far less reliable and, in the end, less survivable or dependable. The Allies also experimented with fitting a modified version of France's spectrum-dispersion cannon design onto the aircraft, to make it score enemy kills even faster while potentially taking down multiple hostiles in a single brilliant attack. However, the spectrum cannons tended to temporarily blind Apollo test pilots, even through their goggles, which was an unexpected safety concern that Angstrom continues to lament to this day. So this design was ill-conceived, as well as prohibitively expensive. The Apollo model now in use, by comparison, is widely appreciated by for its tried-and-true performance.
Today, Apollo Fighters are a common sight in Allied military bases, and frequently take point alongside close-support or bomber aircraft such as Cryocopters or Century Bombers. They have proven to be absolutely vital to this role, for their unparalleled ability to defend these mission-critical assets. At the same time, Apollos excel at hunting down Soviet aircraft reckless enough to trespass into Allied airspace. The sleek angles of these fighter jets, as well as the age-old romantic allure of air combat--not to mention the necessity of having to fight for one's freedom against the ever-present Soviet agenda of a global communist state--have drawn out many brave men to Allied flight schools worldwide in the hopes of one day being the Allies' next famous fighter ace.
Informationen für das Schlachtfeld:
  • Der Himmelsstürmer — Man kann im Arsenal der Alliierten keine spezialisiertere mechanische Einheit als den Apollo finden. Er ist direct auf seine Spezialfähigkeit als Luftüberlegenheitsjäger ausgelegt. Er kann keine Bodenziele angreifen, ist aber schnell genug ihnen zu entkommen.
  • Bordkanone — Anders als andere, für verschiedene Verwendungszwecke geeignete und teurere Lufteinheiten ist der Apollo nur mit einer Waffe ausgestattet. Allerdings ist die Bordkanone äußerst durchschlagskräftig und schneidet sich auch durch die stärkste Panzerung gegnerischer Lufteinheiten wie durch Butter und kann dauerhaft feuern ohne zu überhitzen oder ihre Zielgenauigkeit zu verlieren
  • Upgrade Kit verfügbar — Unter Leitung des Stabes beginnen einige Commander damit neue Versionen des Apollo zu verwenden die auf dem neuesten Stand der Aerotechnik sind. Das Upgrade erhöht die Waffenkapazität, die Panzerung und die Scannerreichweite
  • RTB auf Zuruf — Wie auch einige andere alliierte Lufteinheiten verfüget der Apollo über einen Autopilotmechanismaus der sie sofort zur Basis zurückschickt und dazu einen Nachbrenner einsetzt. Dies lässt den Apollo auch aus brenzligen Situationen schnell und sicher entkommen.
Den vollen Artikel gibts auf der offiziellen RA3 Seite zu sehen.
Weiterlesen...
Alle Zeitangaben in WEZ +2. Es ist jetzt 01:19 Uhr.
