Alt 16-02-2002, 20:51
Benutzerbild von AgentLie
AgentLie AgentLie ist offline
OL Nick: AgentLie
Exclamation Keine Macht den Laggs
Die Laggs sind wohl das größte Problem bei der Demo. Schuld ist nicht Westwood, oder Gamespy, sondern es sind die Spieler, die denken sie könnten mit DSL ihrern eigenen Server aufmachen. Und diese Server laggen dann natürlich. Westwood hat auf der offiziellen Seite folgende Tips gepostet. http://westwood.ea.com/games/ccunive...lish/demo.html
OPTIMIZING CONNECTION SPEED FOR RENEGADE USING THE GAMESPY NETWORK.
With the excitement surrounding our official Renegade Demo launch, there are a number of players starting their own Renegade game servers without the proper bandwidth or computer hardware to support a large number of players online. They mean well, but the end result can be "laggy" server response times and poor gameplay. We're working on a fix to prevent this from being an issue, so please bear with us over the next 24 hours. In the meantime, those of you setting up your own servers should look at our server set-up guide first.
One good way to eliminate poor response times is to filter out non-dedicated servers. These servers are not only sending out tons of info to the connected clients but also drawing everything on their own screen which takes a lot of valuable CPU power. It's best to try and play on a dedicated server, one that is doing NOTHING but sending info back and forth between all of the connected clients.
Here's how to filter those types of servers out. First, click the little down arrow next to "Room Name" in the server list as shown below...
Then, click on the line "Advanced Filtering." Afterward, click on Enter Advanced Filter and set your rule to this:
dedicated = 1 (there's an example below)
If you're running your own server, please keep this in mind!
And if you're a player, or hosting your own server, be sure to set your connection speed properly. The Renegade demo defaults to a 56k connection speed, which is what you'll be playing at if you don't set the correct speed manually. To do this, follow the steps below.
First, launch the "Renegade Multiplayer Demo" icon found on your desktop.
Once the main menu screen appears click on "Multplay Internet."
Next, you will see a "GameSpy" option highlighted, click on it.
Now click on the "Options" button.
Click in the box that says "Connection," select the speed at which you use to access the internet.
Once this is complete, the connection option will be saved.
As mentioned earlier, we're working through the night to improve game performance and expect to address this issue in the next 24 hours. We'll keep you updated at GameSpy, as well as the Westwood site on further improvements and news as soon as they happen.
RENEGADE SERVER SET-UP GUIDE
It is very important that your game is setup to use the correct connection speed for your Internet connection. If the connection speed is not setup properly, it will drastically affect your game performance. This setting communicates to the server how frequently your game should update. If it is set too low, the server does not update your client as often as it could.
If this value is set too high, the server may flood your game with too much information.
If you are setting up a server, it is important that your connection speed is setup correctly. The connection speed for the server determines how frequently clients connected to the server are updated. This has a direct effect on the experienced "lag" of the players connected to your server.
To promote the best gameplay experience for all of our players, the server can only be setup as a dedicated server.
The number of allowable players is automatically detected and set by the game. We STRONGLY recommend that you do not run a server if your connection speed does not meet the following requirements:
Bandwidth > 2.0 Mb for a 32 player game
Bandwidth > 1.0 Mb for a 16 player game
Bandwidth > 0.5 Mb for an 8 player game
Cable modems and DSL are typically set to an upload bandwidth of 128k/sec and are NOT allowed to host.
Ich hoffe damit wird schon ein wenig dem Problem abhilfe geschaffen.
Nasenringe endlichen fallen.
Zaum und Sporen ewig rosten
- George Orwell
Geändert von AgentLie (16-02-2002 um 21:03 Uhr).
Alt 16-02-2002, 22:07
EquinoX EquinoX ist offline
EquinoX hat noch keine Bewertung oder ist auf 0
EquinoX eine Nachricht über ICQ schicken
Ach nee, Schlauberger
Dann müsste das aber bei CS GEnauso sein oder nicht ???
Außerdem wird das auch nur unwesentlich besser, wenn ich auf Dedicated = 1 mache !!!
Soll Westwood halt mal 5 Server sponsoren auf dem man mal Vernünftig zoggn kann...
Naja ich habs im LAN gespielt 4 h und da wars geil *gg*
Alt 16-02-2002, 22:23
Firestorm Firestorm ist offline
Firestorm hat noch keine Bewertung oder ist auf 0
War grad 2h auf nem Super Server, der hatte 155 Mbit Leitung und 32 Spieler !
Alt 16-02-2002, 22:24
OL Nick: AgentLie
tasty
ich wollte es ja nur mal sagen, weil sich so viele bei westwood und gamespy beschweren, die garnichts dafür können. und es ist ja schließlich nur eine demo. die server von westwood kommen dann ja bei der voll version schlauberger
- George Orwell
Alt 16-02-2002, 22:27
Hitman Hitman ist offline
Style: WarCraft
die server in der Vollversion, sind bei Gamespy und bei Westwood.
Alt 16-02-2002, 22:30
Gatnom Gatnom ist offline
Gatnom hat noch keine Bewertung oder ist auf 0
es gibt doch schon 5 westwood server (oder 4 oder 6, was auch immer ). aber ich hab bei denen nen ping von 1000, also total beschissen...
Alt 16-02-2002, 23:03
Senkfuß Senkfuß ist offline
Senkfuß hat noch keine Bewertung oder ist auf 0
Das mit dem dedicated=1 bringt für uns so gut wie nix weil die meisten Server die dedicated sind nicht in Deutschland ist.
Also hat man zu denen dann auch n kack Ping, weil die zu weit weg sind...
Ich hoffe in der nächsten Zeit tut Westwood etwas, oder die Server nehmen zu, oder beides
Ansonsten überleb ich die 2 Wochen nich bis ich es endlich hab...
Alle Zeitangaben in WEZ +2. Es ist jetzt 02:18 Uhr.
