Alt 08-06-2003, 10:25
Question "MiG's unterwegs" oder besser, wie mache ich Boris Waffe nach?
Hi Leute, ich wollte für meinen Pentagon-General den Airstrike machen, den Boris auch hat, also habe ich eine neue Waffe erstellt. Aber kaum will ich die Waffe testen, kommt des Modders bester Feund "Internal Error". Hier mal die Einträge:
Die Unit
; Pentagon General
[PENTGEN]
UIName=Name:PENTGEN
Name=General Pentagon
Category=Soldier
OccupyWeapon=UCAKM; The weapon I use while Occupying. Defaults to 0 (Primary)
EliteOccupyWeapon=UCEliteAKM; The weapon I use while Occupying. Defaults to 0 (Primary)
Occupier=yes ; I can Occupy UC buildings
OccupyPip=PersonBlue ; choices are green yellow white red blue purple
Prerequisite=GAPILE,GATECH
Image=PENTGEN
;;;C4=yes; The Pentagon General destroy the parliament in London
Strength=300
Primary=PentagonGun
Secondary=PentFlare
Armor=plate
TechLevel=10
CrushSound=InfantrySquish
;Insignificant=yes
Sight=2
Speed=4
Owner=British,French,Germans,Americans,Alliance,Russians,Confederation,Africans,Arabs,Yuri Country
RequiredHouses=Americans
AllowedToStartInMultiplayer=no
Cost=5000
Soylent=500
Points=100
;Ammo=10
;Fraidycat=yes
;Civilian=yes
;Nominal=yes
Pip=red
VoiceSelect=
VoiceMove=
VoiceAttack=
VoiceFeedback=
VoiceSpecialAttack=
DieSound=GIDie
Locomotor={4A582744-9839-11d1-B709-00A024DDAFD1}
PhysicalSize=1
MovementZone=Infantry
Trainable=yes
ElitePrimary=PentagonGunE
VeteranAbilities=FASTER
EliteAbilities=STRONGER,FIREPOWER,FEARLESS
ThreatPosed=0 ; This value MUST be 0 for all building addons
ImmuneToVeins=yes
Size=1
;Airstrike stuff
;How many planes to call in
AirstrikeTeam=1;
EliteAirstrikeTeam=2;
;What type of planes to call in
AirstrikeTeamType=FORTRESS
EliteAirstrikeTeamType=FORTRESS
;How long after the planes either leave the map or are destroyed will the next team of planes be ready?
AirstrikeRechargeTime=150;100
EliteAirstrikeRechargeTime=100;50
BuildLimit=1
IFVMode=0
Die Waffe......
; Pentagon General Airstrike
[PentFlare]
Damage=1
ROF=60
Range=12
Warhead=AirstrikeFlare
MigAttackCursor=yes; like Tanya's SabotageCursor override
;Charges=no
;LaserInnerColor = 255,0,0
;LaserOuterColor = 127,0,0;0,0,0
;LaserOuterSpread= 40,80,80;20,40,40
;LaserDuration = 90;15
Projectile=Invisible;LLine2
;IsLaser=true ; this flag tells the game to use the special laser draw effect
IsLine=true
IsHouseColor=true
;Projectile=Lobbed
;;Floater=yes
;Speed=5
;;Lobber=yes
;Bright=yes
Geht das überhaupt nicht oder wenn doch, was habe ich falsch gemacht?
Alt 08-06-2003, 11:14
Benutzerbild von Chriz
Chriz Chriz ist offline
Obeliskelektriker
OL Nick: chrizde
Gib ihm sdoch mal als Waffe "Flare". Das ist die Waffe von Boris, vielleicht klappt es damit. Wenn das nichts hilft, guck mal ob du bei FORTRESS richtig eingestellt ist bzw poste davon mal den Code.
Alt 08-06-2003, 11:40
Benutzerbild von Kroko
Kroko Kroko ist offline
Kroko ist...
DER Warhead=AirstrikeFlare ist ich glaube so ne spez. Art über den auch das AirstrikeTeam gesteuert wird. Also sollte es in der Rules nicht mehrere AirstrikeTeamType geben sonst müssten die ja extra irgendwo definiert werden.
Aber 100% genau weis ich es auch nicht.
Ist nur meine Meinung
Aufgeben gibt`s nicht
http://www.uuumodyr.de/
Alt 09-06-2003, 11:29
Vielleicht kann ich, wie Chriz schon gesagt hat, auch einfach "Flare" eingeben und dann nur dann das Team ändern.....
Hier mal der Eintrag von der "FORTRESS":
; Stealth Bomber
[FORTRESS]
UIName=Name:FORTRESS
Name=Stealth Bomber
Image=FORTRESS
Prerequisite=RADAR,TECH
Primary=Maverick4
CanPassiveAquire=no ; Won't try to pick up own targets
CanRetaliate=no; Won't fire back when hit
Strength=300
Category=AirPower
Armor=heavy
TechLevel=-1
Sight=10
RadarInvisible=yes
Landable=yes
MoveToShroud=yes
;;;Dock=GAAIRC,AMRADR; This is impossible
PipScale=Ammo
Speed=9
;PitchSpeed=0.9
;PitchAngle=0
PitchSpeed=1.1
PitchAngle=0
Cloakable=yes
CloakingSpeed=8
OmniFire=yes
Owner=British,French,Germans,Alliance,Americans
Cost=2000
Points=30
ROT=3
Ammo=2
Crewed=yes
ConsideredAircraft=yes
;;;AirportBound=yes ; If I ever need to land and there are no airports I crash because I can only land on them
GuardRange=30
MaxDebris=3
IsSelectableCombatant=yes
VoiceSelect=IntruderSelect
VoiceMove=IntruderMove
VoiceAttack=IntruderAttackCommand
VoiceCrashing=IntruderVoiceDie
DieSound=
MoveSound=IntruderMoveLoop
CrashingSound=IntruderDie
ImpactLandSound=GenAircraftCrash
Locomotor={4A582746-9839-11d1-B709-00A024DDAFD1}
MovementZone=Fly
ThreatPosed=20 ; This value MUST be 0 for all building addons
DamageParticleSystems=SparkSys,SmallGreySSys
AuxSound1=IntruderTakeOff ;Taking off
AuxSound2=IntruderLanding ;Landing
VeteranAbilities=STRONGER,FIREPOWER,SIGHT,FASTER
EliteAbilities=STRONGER,FIREPOWER,ROF
Fighter=yes
ImmuneToPsionics=yes
ElitePrimary=Maverick3E
PreventAttackMove=yes
Ach, übrigens: Danke für eure Antworten
Alt 09-06-2003, 13:12
Obeliskelektriker
OL Nick: chrizde
Gib deinem General einfach Flare als Waffe und lasse das Team so, das müsste funktionieren.Allerdings ist der Code von der FORTRESS ziemlich verworen
Warum hast du Techlevel=-1 und dann Prequsits? Die brauchst du doch nicht! (Techlevel=11 wäre übrigens besser).
Außerdem solltest du Landable=no eingeben und nicht yes.
Geändert von Chriz (09-06-2003 um 13:15 Uhr).
Alt 09-06-2003, 20:36
Das mit FORTRESS kommt daher, weil man sie voher auf dem Airforce-HQ bauen sollte, klappt aber nicht - dann änder' ich die Sachen um, mal sehn ob's dann funktioniert - momentan funzt's es auch nicht mit Flare....
Alt 09-06-2003, 21:01
Obeliskelektriker
OL Nick: chrizde
Kopiere am besten die Mig und ändere einfach Strenth und so ab. _Das ist der einfachste Weg.
Alt 09-06-2003, 21:09
Jo, werd' ich machen - danke nochmal
Alt 10-06-2003, 09:43
So, ich hab's genauso gemacht wie du gesagt hast, hat aber nich geklappt - wahrscheinlich geht's nur mit Boris.
Alt 10-06-2003, 19:30
Kroko ist...
Also es geht definitiv nicht nur mit Boris.
Habe in meinem Mod so ein AirstrikeTeam einem Fahrzeug gegeben und es klappt.
Nur der Cousor ist der normale nicht der Spez.
Bist du Dir sicher das es an der Flare oder seinem air Team liegt?
Stürzt das Spiel nur ab wenn du diese Waffe benutzt oder schon wenn die Einheit errichtet wurde?
Alt 10-06-2003, 19:38
Kroko ist...
Wir hoffen du hast die FORTRESS auch in die [AircraftTypes] Liste eingetragen!
Alt 12-06-2003, 10:58
Ich hab' die Lösung selbst rausgefunden! (Und übrigens, FORTRESS ist in der Aircraft Type List drin )
1.Schritt: Boris komplett kopieren, Name ändern, Preis etc.
2.Schritt: AirstrikeTeam ändern, wie man will - fertig!
Man kann im Endeffekt nur einer neuen Infanterieeinheit diese Waffe geben, und man muss immer Boris kopieren und umändern!
Alt 12-06-2003, 19:45
Obeliskelektriker
OL Nick: chrizde
Man kann im Endeffekt nur einer neuen Infanterieeinheit diese Waffe geben, und man muss immer Boris kopieren und umändern! [/b]
Wie meinst du das? Ich hab einem Panzer die Waffe gegeben (mit Airstrike-Team) und das geht problemlos.
Alt 13-06-2003, 11:30
Jupp, hab' auch gerade gemerkt das man es auch mit Panzern machen kann - es hat nicht funktioniert weil meine FORTRESS keine Waffe hatte
Alle Zeitangaben in WEZ +2. Es ist jetzt 18:08 Uhr.
