Zurück   CnC Foren > Archive > Übersicht über die Archive > Archiv vB3 > Öffentliche Clanforen > WOW
Alt 21-02-2003, 12:39
Neuer Generals Patch
Version 1.3 - 2/20/03
Issues addressed…
- QuickMatch stability and matching
- General connection fixups behind routers (multiple players behind the
same router, refreshing the player IP after a failed connection)
- Refresh button added to Custom Lobby
- Game List/Player List no longer pops to the top occasionally
- Player List no longer jumps, etc. making it difficult to click on a
name
- Communicator requests addition of buddy to both players. Also,
incoming messages get a sound effect
- Spaces in front of games in Game List no longer allowed
- Game Lists/Player Lists alphabetize in upper and lower case
- Ping tolerance icon adjustment to make more useful
- More accuracy in number of players per game in Game List
1. KNOWN FIREWALL ISSUES AND WORKAROUNDS
1.1. Known Issues
1.2. Wireless SMC Routers
1.3. Linksys Routers
1.4. Other Routers
2. STABILITY ISSUES AND HEAT
3. VIA CHIPSET USERS
4. UNSUPPORTED VIDEO CARDS
5. ACCURATE 1.2 PATCH ISSUES
1.1. Known Issues:
Playing Command & Conquer Generals on more than one PC behind a D-Link router might lead to a disconnect error.
1.2. Wireless SMC Routers:
Below, you will find instructions on how to open the ports of an SMC wireless router. Special thanks to forum regular HautKarl for the following information.
NOTE: This configuration is only for those experiencing connection problems setting up a game Online in Command & Conquer Generals behind a SMC Wireless Router/Firewall, although other SMC firewalls might work with similar setups.
These instructions show how to setup your SMC Wireless Router to open certain ports in the firewall when Generals tries to create or connect to an Online game.
1. Go to the configuration program for your router. To do that, open MS Internet Explorer and in the address box type http://192.168.2.1 (this is the default IP address for the SMC Wireless router; if you changed this address, then you should type the address that you entered the first time that you configured your router). You’ll be prompted for your login and password. If you have never changed your password, then use the default one. Look for it in the SMC instruction manual.
2. Now you should be at the main menu of the SMC setup program. Click in the menu named NAT, then click in the submenu named Special Applications.
3. Now you have to set up one rule per computer connected to the router that will be used to play Generals.
a) Add a triggering port per computer. The Trigger Port specifies which port is used to initiate the connection. It is important not to use a standard port. As you can see below we setup rules for 2 computers and we used port 29900 for the first computer and 29910 for the second computer. In the Trigger Type option select UDP as this is the protocol used by Generals
b) In Incoming Port Range we have to specify the ports that the router will enable whenever the computer establishes a connection through the Trigger Port. Here you will set up a range of ports. SMC routers seem to work correctly if you provide a range with 10 ports, however other firewalls might need wider ranges. Once again, do not use any standard ports or a range that might include a standard port. As you can see in the example below, you have defined a range of 10 ports per connection between 27900 and 27921. In the Public Type option, select UDP, as this is the protocol used by Generals.
c) Repeat this process adding a new rule per computer that will be used to play Generals online. As you can see in the example below, you have setup forwarding rules for just two computers.
d) Once you are done, click the Apply button.
4. Now you have set up each of the computers so each one uses a specific port in your firewall to initiate the connections.
a) Go to the first computer that you are going to use to play C&C Generals and open the My Documents folder. Then go to the folder named Command and Conquer Generals Data and double click in the file named Options.ini
b) Look in the file for the lines:
FirewallBehavior = XX
FirewallPortAllocationDelta = X
c) You have to add a new line FirewallPortOverride that specifies the first of the trigger ports that you already defined when setting up your firewall. In the above example, the first Trigger port was 29900 so the line will be:
FirewallPortOverride = 29900
d) The file should look now something similar to this:
FirewallBehavior = 1
FirewallPortAllocationDelta = 0
GameSpyIPAddress = XXX.XXX.XX.XX
Gamma = 48
IdealStaticGameLOD = High
LanguageFilter = false
MaxParticleCount = 3000
MoveScrollAnchor =
e) Save the file and repeat this process in the other computers, changing the FirewallPortOverride value to the correspondent Triggering Port that you defined while setting up the router (Point 3 of this document).
5. Now start the game in each computer and go to the Options menu, then click in the Refresh NAT option.
6. You are ready to play Command & Conquer Generals Online.
1.3. Linksys Routers:
Below, you will find instructions on how open the ports of a Linksys router in order to play Command & Conquer Generals online. Special thanks to forum regular HautKarl for the following information.
NOTE: This configuration is only for those experiencing connection problems setting up a game Online in Generals behind a Linksys Router/Firewall.
These instructions will show you how to set up your Linksys Router to open certain ports in the firewall when Generals tries to create or connect to an Online game.
1. Go to the configuration program for your router. To do that open MS Internet Explorer, and in the address box, type http://192.168.1.1 (This is the default IP address for Linksys routers. If you changed this address at any time, you should type in the address that you entered the first time that you configured your router). You’ll be prompted for your login and password. If you have never changed your password, then use the default one. This can be found in your Linksys instruction manual.
2. Now you should be at the Main Menu of the Linksys setup program. Click on the tab labeled Advanced settings, then click in the tab named Forwarding. At the bottom of that screen will be a button named Port Triggering. Click on this button.
3. Now you have to setup one rule per computer connected to the router that will be used to play Generals.
a) In Application Name enter the name of the first connection. It can be anything; this is just so you can differentiate them. We suggest you to use Generals1, Generals2, etc, or the Computer name for that connection.
b) Trigger Port Range specifies which ports are used to initiate the connection. In your case, you will only need one per computer; therefore you will enter the same port number in both boxes. It is important not to use a standard port. In the picture below you can see we used ports 27901 to 27904.
c) In Incoming Port Range you have to specify the ports that the router will enable whenever the computer establishes a connection through the Trigger Port. Here you will setup a range of ports. Linksys routers seem to work correctly if you provide a range with 10 ports, however other firewalls might need wider ranges. Once again, do not use any standard ports or a range that might include a standard port. As you can see in the example below, you will define a range of 10 ports per connection between 29901 and 29940.
d) Repeat this process for each computer connected to your router that will be used to play Generals online. The example below shows forwarding rules for four computers.
e) Once you are done, click the Apply button.
4. Now you have setup each of the computers so each one uses a specific port in your firewall to initiate the connections.
c) You have to add a new line FirewallPortOverride that specifies the first of the trigger ports that you already defined when setting up your firewall. In our example the first Trigger port was 27901 so the line will be:
FirewallPortOverride = 27901
Gamma = 48
MoveScrollAnchor =
e) Save the file and repeat this process in the other computers, changing the FirewallPortOverride value to the correspondent Triggering Port that you defined while setting up the router (Point 3 of this section).
5. Now start the game in each computer and go to the Options menu, then click the "Refresh NAT" option.
1.4. Other Routers:
If you own a different brand of router, try applying similar settings to the routers listed above in order to connect to others players online. Check your manufacturer's documentation before applying any changes.
Command & Conquer Generals taxes computer hardware, particularly CPU and system memory, very heavily. This will cause the hardware to dissipate a lot of heat. If your system cooling is inadequate, it will cause the system to become unstable, and possibly crash. This issue will manifest itself in the form of a "Serious Error" message, and/or a blue screen crash.
Here are some diagnostics that you should run in order to find out if your system is stable:
Prime95
http://www.mersenne.org/freesoft.htm
ftp://mersenne.org/gimps/p95v2212.exe
When using Prime95, run the Torture Test until your PC passes the self-diagnostic.
Memtest86
www.memtest86.com
Use Memtest86 to test your system memory's stability. Be sure to let it complete a full pass at least once.
Sandra
http://www.sisoftware.net/?dir=dload...x86&a=&lang=en
Various diagnostics included in this program. This software will also tell you your motherboard and CPU's temperature. Sandra also has a BurnIt test to examine the stability of your system by running a series of tests continuously. However, Prime95's Torture Test is a more reliable way to test your system's stability.
We found that users with VIA motherboard chipsets for AMD and Intel CPUs will encounter crash problems with Command & Conquer Generals. If you own such a motherboard, please go to http://www.viaarena.com and download the latest 4-in-1 drivers. If you continue to experience problems with the game after installing the 4-in-1 drivers, download VIA's version 4.38 of the 4-in-1 drivers. Not having the correct VIA drivers could manifest itself in the form of a "Serious Error" message, and/or a blue screen crash.
Command & Conquer Generals will work properly with ATI Radeon 7500 or newer chipsets, and Nvidia GeForce 2 or newer chipsets. The game will not run properly if your computer has an ATI or Nvidia video card with an older chipset than the ones listed on the box, or a chipset from a completely different manufacturer. These include the following chipsets:
3dfx chipsets
Nvidia TNT2
ATI Radeon Mobility
ATI Radeon 7200
S3 ProSavage
Kyro and Kyro II chipsets
Intel 810e integrated chipsets
If you attempt to run C&C Generals with any of the chipsets listed above, you might encounter a blue screen crash, or a "Serious Error" message. Always make sure that you have installed your manufacturer's latest drivers before running the game.
Some users have patched C&C Generals using incorrect and incorrect 1.2 Patch. If you have done so you will need to reinstall C&C Generals to allow the game to work properly. If you downloaded 1.2 from any server other than ftp.ea.com or the normal Generals Online autoupdate then you likely have the wrong patch.
Alt 21-02-2003, 13:08
Benutzerbild von Give5
Give5 Give5 ist offline
Give5 hat noch keine Bewertung oder ist auf 0
Give5 eine Nachricht über ICQ schicken Give5 eine Nachricht über MSN schicken
OL Nick: Give5
Wann ist der release??
Currently playing
Online: Unreal Tournament 2004
Offline: Dawn of War 2
All-time favorite: Left 4 Dead
Most wanted: Diablo III
Alt 21-02-2003, 13:13
Benutzerbild von Seraque
Seraque Seraque ist offline
Seraque hat noch keine Bewertung oder ist auf 0
OL Nick: Seraque
Gestern!!
Wenn Du es nicht glaubst: Link
www.4tunez.com
Alt 21-02-2003, 13:14
OL Nick: Give5
Gestern? Fett, ich hab seit ein paar Tagen nicht mehr gezockt, sonst hätte ich das gewusst. Is aber geil das der Patch draussen ist, hats was gebracht wegen Lobby und so??
Currently playing
Alt 21-02-2003, 14:53
At0mF1rE At0mF1rE ist offline
At0mF1rE hat noch keine Bewertung oder ist auf 0
OL Nick: At0mF1rE
wegen buddys, lobby und so weiter hats nichts geändert (jedenfalls bei mir nicht)
Alt 21-02-2003, 14:55
OL Nick: Give5
Hab gerade den Thread durchgelsen im Generals Forum, haben sich doch ein paar Dinge verändert aber es gibt immer noch die Sache mit der Ladder......
Currently playing
Alt 21-02-2003, 15:49
Benutzerbild von TrustNo1x
TrustNo1x TrustNo1x ist offline
Obeliskelektriker
TrustNo1x hat noch keine Bewertung oder ist auf 0
OL Nick: TrustNo1
*freu* Da meine Kiste hinter einem Router ist hoffe ich dass dieses Problem nun tatsächlich gefixt wurde. Das wäre schon mal sehr viel wert!
Lasst den Jungs noch ein bisschen Zeit. Ich bin überzeugt, dass sich an der Lobby und am Clan/Tourney-Manager noch einiges ändern wird. 3 Patches innert 1 Woche zeugen davon dass fleissig daran gearbeitet wird. Und ehrlich gesagt ist es mir lieber dass erst die Connection-Problems gelöst werden und der Rest danach.
Ich erinnere mich noch gut an die erste Lobby im TS. Da gab es ähnliche Probleme und noch ähnlichere Reaktionen wie jetzt. Und letztendlich war die TS Lobby genial...
Also, werde heute Abend sicher wieder ein, zwei, drei Generals zocken Gell Seraque
Alt 21-02-2003, 18:10
OL Nick: Give5
Machen wir doch ne Zeit ab und treffen uns in einer Lobby...hab wieder echt bock auf Generals (3 Tage nicht gezockt.. )
Currently playing
Alt 21-02-2003, 18:20
OL Nick: At0mF1rE
ich werde auch dabei sein heute...
aber vielleicht nicht all zu lange (sitze seit 9 uhr morgens am pc, meine mutter hat mich schon 3 mal weggeschickt...). wenn ich pech hab kann ich gar nicht mehr kommen heute, sollte shcon gehen...
aber morgen habe ich wieder von 9uhr morgens zeit zum zocken
Alt 21-02-2003, 18:26
OL Nick: Give5
Morgen is erst mal auschlafen angesagt für mich, muss den Schlaf wieder reinholen
Zum Topic:
Es haben sicher schon ein paar mit dem neuen Patch gezockt, was gibts negatives??
Currently playing
Alt 21-02-2003, 18:36
Benutzerbild von Surli
Surli Surli ist offline
Werde Heute wahrscheindlich etwa ab 21:00 oder 22:00 online sein...
Alt 21-02-2003, 19:03
was hat das ganze jetzt mit dem Patch zu tun?
Leute, das Forum ist auch sonst schon unübersichtlich genug. Bitte haltet Euch an die Topic. Wenn ihr nichts zu der Topic zu sagen habt, dann Ruhe!
Finde es ja auch sinnvoll, einen gemeinsamen Online-Abend abzumachen. Aber das muss nicht unter dem Thema Patch ablaufen, oder? Bitte eröffnet dann eine neue Topic!
Das war jetzt dann die letzte Warnung! In Zukunft werde ich Off-Topic Threads löschen, verschieben und evt. den User gar bannen! Ok?
Alt 21-02-2003, 19:05
OL Nick: At0mF1rE
yep, ich hab schon mit dem neuen patch gezockt...habe noch nicht wirklich eine änderung gefunden...
mein feund sagt, die farben seien anders, je nach schnelligkeit der verbindung oder so was...
@ heute abend
wie wärs mit 19:00 oberste USA lobby?
Alle Zeitangaben in WEZ +2. Es ist jetzt 09:46 Uhr.
