Alt 18-02-2003, 17:50
Elmar Elmar ist offline
Elmar ist...
Elmar eine Nachricht über ICQ schicken
Lösung zu einigen Problemen
Hier etwas für Router etc (Sollte nur von Leuten ausprobiert werden, die sich etwas damit auskennen):
A workable solution to the DirectIP problem that Generals (and other NAT/Firewall-unfriendly games) has with Routers on Windows 2K/XP.
This is only meant to keep people playing UNTIL EAP releases a patch/fix to resolve this!
1) Right click on 'My Network Places' and click Properties.
2) Now right click on 'Local Area Network' and select Properties
3) Find the TCP/IP connection and click on Properties; if only one TCP/IP protocol is there use that, else use the TCP/IP protocol that is bound to your Network card. Now click on Properties.
3) This area requires you have your WAN IP Address, Subnet, DNS, and Gateway info. Do get this info run a DOS prompt, then type 'ipconfig /all' and copy the appropriate information down!
Note: If you use your WAN IP as your static IP number, Windows 2K/XP will say that your IP is already in use. Makes sense, the router is using it, and routing the information to your local IP.
4) Now, in the TCP/IP Properties, click on 'Use the following IP address' and enter in the information from the router.
Note: Do not enter your WAN IP address into the IP address field...leave that alone, but replace Subnet mask, default Gateway, and the perferred DNS server. *Do not click OK yet.*
5) After you have finished, click the Advanced button in the same menu where you just edited your computer to use a static IP.
6) Under IP settings, under IP addresses click on Add... now add your IP address and the Subnet mask of your WAN IP address. Note: *Be sure to look at your router for this information*. Now click on OK.
7) Check your internet, it should still be working.
8) Go into your game now (ie. Generals)
9) Click on 'Options' in the interface (ie. Generals).
10) Look for the online IP, click on the drop down menu and there should two IPs listed; your Local IP => 192.168.X.X and your WAN IP =>150.24.x.x. Select the WAN IP.
11) When you go into Direct Connect, your WAN IP should be there.
12) Make sure all your *NEEDED* ports are open!
ungültiges Passwort?
Überprüfen können Sie Ihre Daten bei
www.gamespyid.com
Dort können Sie auch notwendige Änderungen bezüglich dieses Passwortes vornehmen.
Auch sollten die Leute mal eine alternative E-Mail Adresse angeben.
Nochmal Router, deutsch:
Sehr geehrter Kunde,
bitte gehen Sie einmal in das Optionsmenü von Generals und dort finden Sie einen Wert für Online IP.
Wenn Sie eine Meldung bekommen, die besagt keine Verbindung zu Generals Online möglich dann
klicken Sie bitte auf das Dreieck neben der Online IP und dort müssten Sie noch einen anderen Wert zur Auswahl haben. Diesen wählen Sie bitte aus und Sie sollten sich problemlos mit Generals Online verbinden können.
Aktualisieren Sie bitte auch, in dem Sie den button NAT anklicken.
Dies müssen Sie bei jeder Neueinwahl ins Internet über das Optionsmenü durchführen.
Der kommende Patch Version 1.3 sollte allerdings das Problem beseitigen inkl. Leute die Probleme haben eine Verbindung via Firewall oder Router durchzuführen.
Probiert es einfach mal aus. EA übernimmt keine Haftung für etwaige Schäden....
Alt 18-02-2003, 18:01
kreisch kreisch ist offline
kreisch hat noch keine Bewertung oder ist auf 0
kreisch eine Nachricht über ICQ schicken
OL Nick: modneo1
fehlt nochwas!
für leute die einen router haben:
1.)konfiguriert euren pc als DMZ!
es muss ein normale ip zuweisung sein.keinen speziellen port!
2.)macht das was iner readme vorhanden ist
3.)generals starten und dann auf netakualisieren under optionen.fertig!
4.)man könnte auch die firewall abschalten(ping)
Alt 18-02-2003, 18:59
TheM TheM ist offline
TheM hat noch keine Bewertung oder ist auf 0
also dass was die da oben vorschlagen klingt plausibel, aber is ja ein riesen aufwand !
denn die wan ip wird ja immer neu vergeben und jedes mal generals spielen ändere ich nicht meine tcp/ip einstellungen!
Alle Zeitangaben in WEZ +2. Es ist jetzt 10:30 Uhr.
