Alt 28-03-2007, 09:32
Patch 1.1
So wie wohl alle schon wissen gibt es das Spiel schon zwar nicht für normale Menschen doch die Schweizer/Österreicher und jeder der jemanden kennt der jemanden kennt ..... dürfte im Besitz von C&C3 sein.
Und wie von EA angekündigt gibt es auch schon den Patch dazu.
Zitat von Predator
Hey everyone,
PATCH 1.1 IS LIVE, log online and download now!
This day 1 patch addresses some very important fixes and exploits. I also want to note that we are already working on patch 1.2 which will technically be our first major patch with balance changes, more bug fixes, added maps, etc. That is slated for late April. But today... you get to download patch 1.1 :o)
IMPORTANT NOTE: We have made an option in patch 1.1 that will allow you to turn off the Kane Edition skins if you'd like. This is purely a matter of preference, so if you want the normal skins, download the patch and have at it!
You'll need to log online to download the patch now that it is live.
Below is the change-list.
Version 1.1 Launcher File - March, 2007
This patch for Command & Conquer 3 Tiberium Wars fixes several bugs and exploits:
Exploits
· Scrin Mastermind's Teleport Units ability maximum range reduced.
· GDI Engineers, Nod Saboteurs, and Scrin Assimilators can no longer capture structures when under the effects of the Scrin's Phase Field ability.
Optimizations
· Improved video playback on low-end system configurations.
Balance Changes
· Scrin Storm Column cost / build time increased to 3,000 credits / 30 seconds.
· Scrin Buzzer health reduced to 75 and weapon damage changed to SNIPER.
Bug Fixes
· Fixed an error that would occasionally result in a crash in Nod vs. Nod matches on the multiplayer map Deadly Sertao.
· Fixed issues with automated map transfer ability in multiplayer.
· Fixed an error that would sometimes cause a Commentator's telestrator drawings to not erase when intended during BattleCast matches.
· Fixed issues with replay file playback.
· Fixed placeholder text and chat log errors with the Comrade in- game chat window.
Other Changes
· References to Nod's "Avatar Warmech" unit have been changed to "Avatar".
-Predator
Message was edited by: EALA Predator (C&C)
Quelle
ftp://ftp.ea.com/pub/eapacific/cnc3/.../Lang-german16
ftp://ftp.ea.com/pub/eapacific/cnc3/...1/Lang-german/
Auf Deutsch:
Command & Conquer 3 Tiberium Wars(tm)
Launcher-Datei Version 1.1 - März 2007
Dieser Patch für Command & Conquer 3 Tiberium Wars behebt folgende
Bugs und Exploits:
Exploits
· Die maximale Reichweite der Teleportieren-Fähigkeit des
Masterminds der Scrin wurde reduziert.
· GDI-Ingenieure, Nod-Saboteure und Scrin-Assimilatoren können
keine Gebäude mehr einnehmen, solange sie unter dem Einfluss des
Phasenfelds der Scrin stehen.
Optimierungen
· Verbesserte Video-Wiedergabe auf Low-End-Systemen.
Änderungen im Balancing
· Kosten der Scrin-Sturmsäule / Bauzeit auf 3.000 Credits
/ 30 Sekunden erhöht.
· Gesundheit der Scrin-Buzzer auf 75 reduziert und Schadenstyp der
Waffe auf SNIPER geändert.
Folgende Bugs wurden behoben
· Gelegentliche Abstürze bei Nod gg. Nod-Multiplayer-Matches auf der
Karte Deadly Sertago.
· Probleme mit dem automatischen Transfer der Karten im Multiplayer.
· Ein Fehler, bei dem manchmal die Telestrator-Zeichnungen des
Kommentators während eines Battlecast-Replays nicht wie gewünscht
gelöscht wird.
· Probleme bei der Wiedergabe von Replays.
· Platzhalter-Texte und Fehler im Chat-Log des Comrade Ingame-Chatfensters.
Weitere Änderungen
· Ein falscher Verweis in der Readme.txt auf den Ordner in dem Spielstände
unter Vista gespeichert werden wurde korrigiert, Hinweise zur EA Link-Version
des Spiels wurden hinzugefügt, Bekanntgabe der In-Game-Werbung wurde hinzugefügt
(Hinweis: Die EA Link-Version dieses Spiels wird mit dieser neuen Readme.txt
ausgeliefert).
Ende der Launcher-Datei
Und da es scheinbar schon Probleme mit dem Patch gibt, hat ein Entwickler auch einen Workaround und eine Entschuldigung gepostet.
Zitat von Smudge
It sounds like some folks are having a problem with the 1.1 patch. This is what is being reported:
  • You patch to 1.1 successfully, or in a very small number of cases you attempt to patch to 1.1 and encounter an error.
  • You uninstall the game
  • You reinstall the game
  • When you go online again you are prompted to patch, at which point the game informs you that you have a corrupted install and need to reinstall. Boom -- cycle of sadness.
We've been able to reproduce this problem on the dev team and have a temporary solution. Here's how to fix it.
  1. Uninstall the game
  2. After you uninstall, go into the installation directory and delete any and all subfolders that you may see remaining. (If you're having trouble finding it, the default installation directory is "Program Files\Electronic Arts\Command & Conquer 3.") You may see subfolders named "Patches" and/or "RetailExes." Blow it all away.
  3. Reinstall the game
  4. Through the Command Center, or by simply going online, install the 1.1 patch. This time the patch should install correctly.
This is just a temporary workaround. We will be readying an automated solution to this problem and expect to make it available sometime soon, but if you've been bitten by this issue you should be able to get back online using this technique.
I know that this can be frustrating and we are very sorry if you've encountered problems today. We are watching these forums very closely and will read every post. We are committed to fixing all outstanding issues as quickly as we can.
- Smudge
Quelle
Mal schauen, ob ich im laufe des Tages eine Übersetzung zu mindest für das Workaround hinbekomme.
Außerdem ist der Ankündigung auch der Patch 1.2 von Predator auf Ende April terminiert worden. Na dann mal schauen.
Geändert von Naos (28-03-2007 um 20:31 Uhr).
Alle Zeitangaben in WEZ +2. Es ist jetzt 23:24 Uhr.
