Kick2Desktop Lösung?
auf dem englischen board gabs ne neue message bezüglich des kick2 bugs. konnte leider noch nicht ausprobieren obs klappt. (but i hope so) ---(irgendwie hört sich das viel zu einfach an)----
_____________________________________________ PATCH BUG FIXED! ---------------------------------------- Hello everyone, well I recently gave up on RA2 with all the crashing probs I had. Well I finally got off my lazy @$$ and started figuring out the error. Well I fixed it. This should work for about 99% of you, if this fails then call WW or go to their chat rooms and maybe they can help you. Well heres what I did. Right click on desktop, go to properties, go to settings, advanced, performance, and finally you will see a hardware acceleration thing. It prolly is on full for most of you, though you got to put it down 2 notches from full. That means it will be one notch away from lowest setting. After restart your computer like it asks and run the game. It should now not crash although now and then you might see the game freeze for half a second looking like its trying to crash though it can't. Also here are things to do just to make sure you get optimum performance from the game, have a nice clean HD although mine is beyond cluttered its unbearable and have about 2 to 3 things running in the background or on the taskbar( I only have Explorer on it). WooHoo that should fix it for all you people having the prob just like I did. Well I am new to the message board, this is my first response since I found it out like 5min ago, if it works at least thank me for gettin off my lazy @$$ L8r all. [Dieser Beitrag wurde von Naos am 14. März 2001 editiert.] |
Kurz und bündig:
Die Hardwarebeschleunigung unter "Leistungsmerkmale" in "Eigenschaften von Arbeitsplatz" auf "1 Strich von links" setzen... Ob's wirklich hilft ? ------------------ Cya <IMG SRC="http://www.cncboa.de/images/sven_sign_k.gif" border=0> Community - Foren [Dieser Beitrag wurde von Sven am 14. März 2001 editiert.] |
hats schon wer ausprobiert?
laut Rückmeldung auf dem WS-Board: nein http://www.cncboard.de/smilies/frown.gif
------------------ cu <FONT COLOR="red">Gersultan</FONT c> ********************************* <FONT COLOR="blue">Leader of CnCBoard Clan [CnCBoa] </FONT c> <FONT COLOR="lightgreen">Admin of CnCBoa </FONT c> <FONT COLOR="yellow"> Schwer is zu hüten, was jedermann gefällt </FONT c> |
die obige "bug-fix" methode war einer der ersten vorschläge deutscher seite nachzulesen in irgend einem der unzähligen und unseligen threads auf "ww anschlagbrett". es hat natürlich nicht funktioniert. ww interessiert die ganze sache überhaupt nicht, denn andernfalls hätten die mal dazu stellung genommen und die lage geschildert und sich geäussert was sie vorhaben bzw. woran sie arbeiten. die haben nichteinmal ihre schuld eingestanden sondern wollen ihr unvermögen amd in die schuhe schieben.
evab |
hehe, typisch ww ebenhttp://www.cncboard.de/smilies/laugh.gif
Der Lösungsvorschlag kam von einem User, WS hat nix damit zu tun (außer dem Patch und dem Problem http://www.cncboard.de/smilies/biggrin.gif ) ------------------ Cya <IMG SRC="http://www.cncboa.de/images/sven_sign_k.gif" border=0> Community - Foren |
Jetzt hatte ich den Scheiß auch mal. War grad mitten im Spiel gg Edelkrieg und gerade als ich sein halbes Lager gesprengt habe flieg ich zu Desktop, und tschüß, Lost by Disconnecting. So ein Mist. Soweit ich weiß kann der Gegner den ja net herbeiführen also lags an mir (bäääähhh!!!! Schluchz, ich will meine Punkte!!!). Aber kann man denn da nix machen. Ich will nicht noch mehr Spiele so verlieren. ------------------ Vertraue auf Allah, aber mauere den Bauhof lieber ein! |
ich hatte auch eben meinen ersten kick to desktop...zum glück war es nur ein washgame*aufatme*
Also bei mir nützt das garnix, ich werde so 5 mal pro Abend zum Desktop gekickt !
AMD TBird 1200 @ 1400 Mhz 384Mb RAM Mushkin High Performance REV.2 Cas 2 WinFast Leadtek GeForce Ultra Detonator 10.80 & 11.00 Mix (NitroSet v1.02) Asus A7V 133A VIA 4.29 Soundblaster Live 5.1 Retail DVD Pioneer A05SZ CD Plextor PXW-1610A Promise Fasttrak 100 2 x IBM DTLA 307045 Raid 0 Nu sach mir ma einer warum ich so oft zu Desktop fliege, und zwar erst seit dem 1.004 Update, vorher nie Probleme ! |
Hi BBMV,
habe so fast die gleiche Ausstattung wie Du. Nur den 1,2 GHZ hab' ich so belassen, Speicher sind 256 MB (ein Riegel) und Grafikkarte ist ne Elsa Geeforce GTS 32 MB, neuester Detonator von NVidia. Aber Board, Harddisks, Soundkarte und DVD sind die gleichen. Hab' nur keinen Raid gemacht, laufen aber beide am Promise-Controller. Der K-t-D kommt auch nur sporadisch aber deutlich zu häufig vor. Es gibt auch Tage, da hab' ich den nicht. Welches Motherboard-Bios hast Du denn? Ich hab 1.04. Via ist bei mir noch 4.28, werde aber 4.29 auch noch installieren. Das Problem tauchte wirklich erst ab Patch 1.004 auf, also eindeutig im Zusammenhang! [ 21. März 2001: Beitrag editiert von: joshix ] |
Hi joshix
Man das kotzt mich an ein 5000,- Mücken Rechner und Westwood ist zu doof nen Bugfix zu machen ! Ich bin froh wenn ich überhaupt mal ein Match zu Ende kriege. BIOS ist auch 1.04 Ich pobiere hier Deto´s Bios und DirectX wien blöder alle Versionen die es überhaupt gibt aber nix ändert sich ! Hab auch schon alle Versionen der RAm Settings im Bios durchprobiert weil der Mushkin mit 2-2-2 erkannt wird hab ich mal sanfter eingestellt aber auch da keine Änderung Der Ram ist einer der Besten den es so gibt läuft auf 2-2-2 bis 145Mhz FSB stabil ! Auf 3-3-3 bis 156Mhz FSB ! Wenn sich net bald was tut fahr ich nach England und werf ne RA2-CD als Briefbombe bei Westwood ein ! :D Warum gehen die tollen Programmierer von Westwood net aufs Patch 1.003 zurück ? Ich empfehle dir den VIA 4.29 und den Detonator Mix 10.80 & 11.00 (NitroSet v1.02), das Ding geht echt ab wie die Luzie. Ich hab so 10% Leistungssteigerung beim 3D Mark 2001 SeeYa BBMV [ 22. März 2001: Beitrag editiert von: BBMV ] |
Nana, haltet euch mal zurück mit unflätigen Äußerungen bzgl. Personen bei Westwood!
Ich habe es bereits zweimal hier auf dem Board geschrieben, dass dieses Problem im Patch 1.005 behoben sein wird! |
Uii sorry dann entferne das Wort Deppen doch bitte in meinem Post oben und ersetzte es durch ein netteres :D
Solltest du vielleicht machen ;)
Naja, wie gesagt - mit Patch 1.005 wird alles besser :) |
Hehe ich wust garnet das ich selbert editieren darf :D
So besser ? :D |
| Alle Zeitangaben in WEZ +2. Es ist jetzt 09:14 Uhr. |
