-   -   2 WICHTIGE Fragen (http://www.cncforen.de/showthread.php?t=21401)
exuser 17-11-2002 13:56
2 WICHTIGE Fragen
Also, wr haben 2 Probleme :
1. Der YR Finalalert Editor zeigt die neuen TR einheiten etc. net an. Wie soll ich da missionen machen, wenn ich nicht shee, was ich tue ? Also wie löst man das prob ?
2. Der Visceroid in YR muss aus bestimmten gründen eine Infanterie sein. Also brauch er nen Art.ini eintrag. Aber seht selbst :
[VISC_LRG] ; Boris
Sequence=ViscSequence
Crawls=no
Remapable=no
FireUp=3
Image=Vislr
[VISC_SML] ; Boris
Crawls=no
Remapable=no
FireUp=3
Image=Vissml
[ViscSequence]
Ready=0,90,1 ; waiting doing nothing
Guard=0,90,1 ; guarding - usually same as above
Walk=0,90,1 ; while walking
FireUp=0,90,1 ;firing while standing up
Idle1=0,90,1,W ;facing one direction
Idle2=0,90,1,E ;facing another direction
Paradrop=0,90,1 ;when paradropped (holding parachute straps)
Down=0,90,1 ;going from standing to prone
Crawl=0,90,1 ; crawling and moving
Up=0,90,1 ; going from prone to standing
FireProne=0,90,1 ; firing while prone
Cheer=0,90,1,E ;cheering anim (when user presses "c")
Panic=0,90,1 (panic (usu. prone sequence if not a civilian)
Fly=0,90,1 ;flying (moving in air)
Hover=0,90,1 ;idle in the air
FireFly=0,90,1 ;firing while flying
Tumble=0,90,1 ;falling after dieing (e.g rocketeer crashing)
Tread=0,90,1 ; treading water
Swim=0,90,1 ; swimming
WetAttack=0,90,1 ;attacking while in water
WetIdle1=0,90,1,S ;idle anim in water
WetIdle2=0,90,1,E ;idle anim in water
WetDie1=0,90,1 ;dying anim in water
WetDie2=0,90,1 ;dying anim in water
Deploy=0,90,1 ; deploying (eg GI deploying)
Deployed=0,90,1 ;deployed still frame
DeployedFire=0,90,1 ; firing while deployed
DeployedIdle=0,90,1 ;idle deployed
Undeploy=0,90,1 ; undeploying
Hier auch mal der Rules.ini eintrag :
[VISC_LRG]
UIName=0Name:Visceroid
Name=Adult Visceroid
Insignificant=no
Image=VISLRG
Nominal=yes
AltImage=VISLGATK
Strength=1000
Category=Civilian
Armor=heavy
TechLevel=-1
Sight=3
Speed=8
TiberiumHeal=yes
Owner=Civilian
AllowedToStartInMultiplayer=no
Cost=1
Points=50
ROT=16
MaxDebris=0
Locomotor={4A582741-9839-11d1-B709-00A024DDAFD1}
MovementZone=Normal
LargeVisceroid=yes
ThreatPosed=20
Primary=SlimeAttack
Secondary=MutatorSlime
GuardRange=10
ImmuneToVeins=yes
Crushable=false
[VISC_SML]
Name=Baby Visceroid
Nominal=yes
Insignificant=no
Image=VISSML
Strength=400
Category=Civilian
Armor=light
TechLevel=-1
Sight=1
Speed=8
Owner=Civilian
Cost=1
Points=50
ROT=16
MaxDebris=0
TiberiumHeal=yes
MovementZone=Normal
SmallVisceroid=yes
Primary=SlimeAttackSml
ThreatPosed=0
GuardRange=5
ImmuneToVeins=yes
Crushable=false
So, und nun das Problem :
Sobald man mit ner einheit in die nähe der viscs kommt, bleiben die stehen, rühren sich nicht mehr, und hängen in ihrer anim fest, also die bildanim bleibt sehen. Bei welchen, die aus Infanteristen mutiert sind, hängt das bild von anfang an.
Mosch, du kannst doch bestimmt helfen. ;)
Chriz 17-11-2002 23:08
Wenn Final Slert GAR KEINE TR-Einheiten anzeigt (nur normale YR-Einheiten), musst du bei Optionen > Einstellungen "Suporrt Missoin Discs an Mods" einstellen. Sind die Einheiten nur unsichtbar (wird keine Grapgik angezeigt), liegt dass an der falschen mix-Datei: Dgrafiken müssen in der ecache.mix und expand.mix und nicht in ecachemd.mix und expandmd.mix da FA diese nicht unterstützt (das Prob. ist aber - glaub ich - in der letzten Version von FA behoben worden).
exuser 18-11-2002 08:05
Ich habe das so eingestellt, die einheiten sind unsichtbar, aber ich kann sie platzieren.
Naja, ich denke, ich habe die neueste version davon, und die dateien sind in den expandmds und ecachemds so wie sichs gehört.
moby3012 18-11-2002 09:47
also ich kann mich erinnern das selbe prob gehabt zu haben ich hab das glaub ich net gelöst bekommen. AAAAber meines erachtens hab ich gelesen das im neusten FAYR das problem behoben worden sein soll.
ftp://ftp.westwood.com/pub/
exuser 18-11-2002 15:43
OK, und wo bekomme ich die neue Version ?
Ach ja und antwortet bitte auch auf die andere Frage, die ist fast wichtiger !
Chriz 18-11-2002 21:29
Zu 1. Also wie gesagt, die VXL-Dateien / shp-Dateien müssen in die ecache.mix und expand.mix und nicht in die ecachemd.mix und expandmd.mix diese wurden von FA noch nicht verarbeitet, dann müsst es funktionieren (bei mir hats gefunzt).
Die neue Version (V1.01) findest du hier http://westwood.ea.com/games/ccunive...mapeditor.html . Hier müsst der Fehler behoben sein.
Zu 2. Hier gibs mehrere Möglichkeiten:
Bist du sicher dass die Einträge
AltImage=VISLGATK
LargeVisceroid=yes
Image=VISSML
SmallVisceroid=yes
in YR noch funktionieren? Lösch sie zur Probe mal am besten.
B) Außerdem könnte es auch ander ViscSequence liegen , wenn sie falsch ist (kannt ja mal dem Visceroiden mit Image=E1 ein anderes Ausehen geben und testen ob der Fehler dann auch auftritt.
C) wenn alles nichts hilft, poste mal die Waffen, vielleicht liegts an ihnen.
Der_Mosch 19-11-2002 00:56
Zu Punkt 1 sag ich nichts mehr, das wurde zur Genüge erklärt. Zu Punkt 2.... gib mir a) die Waffe und b) die Information, ob du die Sequence selber geschrieben hast, da ist einiges an unnützem Zeug drin und ausserdem hast du einen vollkommen unbewegten Visceroiden, keine Animation whatsoever :D Es leigt mit sehr hoher Wahrscheinlichkeit aber an der Waffe, da diese Infanterie beeinflusst und nichts anderes. Also bitte einmal den Waffencode her.
exuser 19-11-2002 08:41
Also, hier ist erstmal die Sequence :
[ViscSequence]
OK, is viel Müll drin, aber da der Visc sich eh überall gleich bewegt, hab ich das auch gleich mal bei allen sachen eingestellt.
Und hier die Waffen(sind 3) :
[SlimeAttack] ;Sekundärwaffe des großen
Damage=100
ROF=80
Range=1.3
Projectile=Invisible
Speed=25
Warhead=Slimer
Report=VICER1
[SlimeAttackSml] ;Primärwaffe des kleinen
Damage=50
ROF=80
Range=1.3
Speed=25
Warhead=SlimerSml
Report=VICER1
[MutatorSlime] ;Primärwaffe des großen
Damage=100
ROF=80
Range=1.3
Speed=25
Warhead=Mutate
Report=VICER1
Der_Mosch 19-11-2002 09:21
Dass die Sequence funktioniert ist klar, nur ohne grossartige Veränderungen :D
Zu den Waffen... ich habe eigentlich auch die Warheads und Projectiles erwartet ;)
exuser 19-11-2002 14:35
Ups :)
Hier sind die Warheads :
[Slimer]
Verses=0%,0%,0%,100%,100%,100%,100%,100%,100%,100%,100%
InfDeath=0
[SlimerSml]
Verses=100%,100%,100%,100%,100%,100%,100%,100%,100%,100%,100%
InfDeath=0
[Mutate]
Verses=100%,100%,100%,0%,0%,0%,0%,0%,0%,0%,0%
InfDeath=9
Und hier die Projektile :
[Invisible]
Inviso=yes
Image=none
So.
Ach ja zu dem Editor :
Selbst mit dem neuesten werden einzig und allein die Tiberiumbäume korrekt angezeigt, Tiberium, sowie gebäude und einheiten bleiben weiter unsichtbar !
Der_Mosch 19-11-2002 15:55
Sieht alles ganz OK aus, bist du dir sicher, dass der Fehler beim Visc liegt?
Chriz 19-11-2002 17:18
Ich würd Die Waffenreichweite auf 1.5 und den Waffenspeed auf 100 umändern. 1.3 und 25 sind für mich recht ungebräuchliche Werte.
PS: komisch, bei mir liest Finalalert die Enheiten in der expand.mix ein:confused:
exuser 19-11-2002 17:32
Nein, ich meine, das neue liest die expandmd nicht ein.
Alle Zeitangaben in WEZ +2. Es ist jetzt 03:26 Uhr.
